Component: Level (DSP)
Revision as of 13:27, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Level component
Allows for detection and collection of peaks, troughs and averages.
Here is a basic example of the Level component. The example collects the max, min and average readings from the buffer and displays them on the LCD display.
FC6 Icon.png Level
The values in the buffer are defined using the InputADC component.
Min: Minimum (smallest) value read from the buffer.
Max: Maximum (largest) value read from the buffer.
Average: Rolling average calculated from the values inside the buffer.
Fc9-comp-macro.png ReadTroughArray
Returns the lowest value from the last "Decay" number of buffers.
Returns the lowest value from the last "Decay" number of index locations.
[[File:]] - Return
Fc9-comp-macro.png ReadAverage
Returns the average from the last "Decay" number of index locations.
[[File:]] - Return
Fc9-comp-macro.png ReadPeakArray
Returns the highest value from the last "Decay" number of buffers.
Fc9-comp-macro.png ReadAverageArray
Returns the average from the last "Decay" number of buffers.
Returns the highest value from the last "Decay" number of index locations.
[[File:]] - Return
Fc9-comp-macro.png ResetRecords
Allows the peak and trough to be reset back to default values.
Fc9-bool-icon.png - BOOL ResetPeak
Fc9-bool-icon.png - BOOL ResetTrough
Fc9-type-17-icon.png Connect To
Fc9-type-7-icon.png Decay on Peak/Trough
Yes - The Peak and Trough value will only be maintained for the decay number of buffers. No - The record Peak and Trough values will be maintained until reset.
Fc9-type-14-icon.png Decay
Configures how many buffers or values to allow a record to persist
Fc9-conn-icon.png Simulations
