Component: File (SD/SDHC Card) (Storage)
Revision as of 13:28, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 3.0
Category Storage
File (SD/SDHC Card) component
File component allowing access to read and write files on a SD/SDHC card. Also compatible with micro SD/SDHC cards, please note the pin layout is subtely different for these. The component automatically detects the filesystem on the card on initialise so FAT16 and FAT32 are fully supported. When used in simulation provides read/write access to files on the local windows file system.
Reading data from a text file
Example to read a text file from a SD card or from a text file in simulation and display on a 16 x 2 character LCD. The text file needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FC6 Icon.png FAT Read File File:Test.txt
Console showing current 512 byte sector data
Console showing high level FAT status
Parsing a standard .BMP image file
Example to read a bitmap image file from a SD card or from a bitmap file in simulation and display on a graphical LCD. The bitmapfile needs to be in the same directory as the Flowcode .fcfx project file for the simulation to run correctly. FC6 Icon.png FAT display Bitmap Demo bitmap files referenced in the example.
File:FATDemoBitmaps.zip
Picture showing a bitmap being displayed on a GLCD component.
Data logger Simple
Example showing how to take a collection of analogue readings and save them into a text based file, the simple way. FC6 Icon.png FAT data logger simple but slow
Data logger Advanced
Example showing how to take a collection of analogue readings and save them into a text based file, the fast way. FC6 Icon.png FAT data logger fast
Log Keypad Presses
Example showing how to poll a keypad for key presses. Each key press is shown on an LCD and appended to a log file as an ASCII character using the FAT component. FC6 Icon.png Keypad Press Log
Streaming Audio Files
Example showing how to steam out .wav audio files from an SD card using a 16-bit @ 16KHz file format. A free program such as Audacity can be used to create or edit the .wav files. FC6 Icon.png WAV Streaming
Fc9-comp-macro.png ReadStringFromFile
Reads a string from the currently open file. Auto increments the position in the file. An empty string signifies the end of the file has been reached.
Fc9-u8-icon.png - BYTE NumBytes
Maximum number of bytes to attempt to read
Fc9-u8-icon.png - BYTE EndChar
Ends the string if the value specified is found, default is 0
Fc9-comp-macro.png WriteByteToBuffer
Writes a single byte to the current 512 byte local sector buffer.
Fc9-u16-icon.png - UINT Address
Address Range 0 - 511
Fc9-u8-icon.png - BYTE Data
Data Byte to write to the buffer
Fc9-comp-macro.png MoveToNextFileSector
Attempts to move to the next sector in the file. When reading a file you would leave force next sector set to 0. When writing a file you would leave force next sector set to 1 to allow new sectors to be created as the file grows. Returns 0 for success
Fc9-u8-icon.png - BYTE Force_Next_Sector
0 = Don't add new sector, 1 = Add new sector if we are at the end of the file
Fc9-comp-macro.png AppendByteToFile
Adds a single byte to the end of the currently open file, useful for inserting the value 0 into binary file types. Returns 0 for success.
Data to append to the end of the file
Fc9-comp-macro.png ReadFileSector
Overwrites local buffer with the current file sector from the disk. Used to restore the local sector buffer with the actual sector stored on the card. Return = 0 : Local buffer refreshed with current card sector Return > 0 : Error
Fc9-comp-macro.png CloseFile
Closes the current open file
Fc9-comp-macro.png ReadByteFromFile
Reads a byte from the currently open file. Auto increments the position in the file. A return value of 0 may signify the end of the file has been reached (depending on the contents of the file).
Fc9-comp-macro.png DeleteFile
Searches for and deletes a file in the current folder location on the card. Default = Root Returns 0 for success.
8.3 format filename e.g."file.txt"
Fc9-comp-macro.png ReadByteFromIndex
Reads an arbitrary byte of data from the current open file. Return = Data byte read from the local sector buffer. Experimental and potentially slow if navigating backwards through the file.
Fc9-u32-icon.png - ULONG Address
Contains the position of the byte to be read from the file
Fc9-comp-macro.png CreateFile
Creates a file in the current folder location on the card. Default = Root Returns 0 for success File must be opened using "Open_File" after creation before writing any data.
Fc9-comp-macro.png ScanCurrentFolder
Method for retreiving file or folder names for the card to allow for dynamic file opening or playback. Does not currently simulate. 0 - Filetype found and stored into string array, 1 - End of folder reached, 2 - Filetype mismatch 3 - Empty
Fc9-u16-icon.png - UINT Current_Idx
Contains the current pointer in the directory table. Values from 0 to 511 to completley search the current folder for a files or folders
Fc9-u8-icon.png - BYTE Scan_Type
Sets the scan to search for Files or Folders. 0 = Scan for files, 1 = Scan for folders
Fc9-comp-macro.png ReadByteFromScan
Returns a byte of the name of the file or folder retreived from the Scan_Current_folder function. Return = ASCII byte at position Idx from the folder name or file name at position Current_Idx in the directory
Fc9-u8-icon.png - BYTE idx
0 - 11 for a file, 0 - 7 for a folder
Fc9-comp-macro.png OpenFolder
".." - Jumps up a directory, if at root then remains in root "root" - Jumps directly back to the root directory "foldername" - Opens folder named foldername
Fc9-string-icon.png - STRING Folder_Name
Fc9-comp-macro.png ReadByteFromBuffer
Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer.
0 - 511 - Contains the position of the byte to be read
Fc9-comp-macro.png ReadFileLength
Returns the number of bytes in the current sector that are used by the current open file. Return = 512 - Sector is filled with file data Return < 512 - Last sector of the file, Retval specifies how many bytes of data are remaining in the sector
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png OpenFile
Searches for and opens a file for reading or writing from within the current directory on the disk. Returns 0 for success.
8.3 filename of the file we are trying to open e.g. "file.txt"
Fc9-comp-macro.png WriteFileSector
Overwrites the current sector on the memory card with the contents of the local sector buffer. See write_byte_to_buffer function. Return = 0 - File sector written successfully. Return > 0 - File sector write error
Fc9-comp-macro.png SetFileIndex
Sets the current file index and used to switch between several open file streams. Default = 0.
Fc9-u8-icon.png - BYTE File_Index
File index ranges from 0 to (Max Concurrent Files - 1)
Fc9-comp-macro.png AppendStringToFile
Adds the contents of the data string parameter to the end of the currently open file. Returns 0 for success.
Fc9-string-icon.png - STRING Data_String
Fc9-comp-macro.png SetByte
Fc9-u32-icon.png - ULONG Int
Fc9-u8-icon.png - BYTE Ix
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png ReadFileSize
Reads the entire size of the current file in bytes.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png GetByte
Gets a byte from an int
Fc9-comp-macro.png SetTimeAndDate
Sets the current time and date. Time = (Hour << 11) + (Min << 5) + (Sec >> 1) Date = (YearFrom1980 << 9) + (Month << 5) + (Day) Additional details can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat
Fc9-u16-icon.png - UINT Time
Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2
Fc9-u16-icon.png - UINT Date
Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980
Fc9-comp-macro.png Initialise
Attempts to communicate with the SD card and if successful sets up the file system. Returns 0 for success.
Fc9-type-14-icon.png Max Concurrent Files
Specifies how many concurrent files can be opened at any one time. Use the SetFileIndex macro to switch between concurrent files.
Fc9-type-16-icon.png End Of File
Specifies the way the ReadByteFromFile function indicates the end of a file. 8 Bit mode - End of the file is represented by the value 0, read multiple times to confirm that the 0 is not simply data. 16 Bit mode - End of file is represented by the value 512 allowing the values 0 - 255 to represent valid data.
Fc9-type-20-icon.png Root Directory
Directory flagged as root for simulation Default: $(srcdir) is the current project source directory. Modern windows systems do not like you writing files to a hard drive root directory so a directory off the root is advised.
Fc9-type-16-icon.png API
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png Initial Prescaler
SPI initial clock divider - Frequency should be under 400khz to allow startup to work correctly.
Fc9-type-16-icon.png High Speed Prescaler
SPI high speed clock divider - Once startup is complete this is the rate that will be used to transfer data
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Auto Insert Card
When set to yes the SD card will be automatically inserted at the start of simulation, Otherwise you must manually click the card on the panel to insert or remove.
Fc9-type-16-icon.png Sim Type
Defines the simulation type. The default is to use the Windows file system to allow for reading and writing files. The alternative is to use the CAL functionality to allow the SPI transactions to be passed onto a seperate handler e.g. for logging or debugging purposes.
