Component: Water Sensor (Grove 101020018) (101020018) (Environmental)
Revision as of 13:28, 17 November 2021 by Wiki bot (talk | contribs)
Category Environmental
Water Sensor (Grove 101020018) component
The water sensor uses a 1M ohm pull-up resistor. The resistor will pull the sensor trace value high until a drop of water shorts the sensor trace to the ground trace. You can use it with an analog input pin to detect the amount of water in contact between the grounded and sensor traces.
Fc9-comp-macro.png GetIntValue
Returns the analog reading as an integer value.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetFloatValue
Reads the analog value as a floating point value between 0 and 100
Fc9-type-14-icon.png Aquisition cycles
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Simulations
Fc9-type-1-icon.png Tang Color
Colour of the moving part of the slider.
Fc9-type-1-icon.png Marker Color
Colour of the marker line across the slider tang.
