Component: Injector (GPS NMEA) ()
Revision as of 13:28, 17 November 2021 by Wiki bot (talk | contribs)
Category
Injector (GPS NMEA) component
Comms data injector to allow simulation of NMEA style GPS messages
GPS Example File FC6 Icon.png GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png RxByteCount
Returns the number of bytes currently sat in the receive buffer.
[[File:]] - Return
Fc9-type-21-icon.png Data Period (ms)
Amount of time in milliseconds to wait between each GPS NMEA packet is sent. Default 1000.
Fc9-type-21-icon.png Circular Buffer Size
Max number of bytes the receive queue can hold. Default 1000.
Fc9-type-7-icon.png Data Valid
Injected GPS data validity
Fc9-type-15-icon.png Altitude
Injected GPS Altitude
Fc9-type-15-icon.png Course Over Ground
Injected GPS course over ground (COG)
Fc9-type-15-icon.png Dilution Of Precision
Injected GPS dilution of precision (DOP)
Fc9-type-15-icon.png Ground Speed
Injected GPS ground speed (Knotts)
Fc9-type-15-icon.png HDOP
Injected GPS horizontal dilution of precision (HDOP)
Fc9-type-15-icon.png Latitude
Injected GPS lattitude
Fc9-type-15-icon.png Longitude
Injected GPS longitude
Fc9-type-21-icon.png Number Of Satellites
Injected GPS number of active satellites
Fc9-type-15-icon.png VDOP
Injected GPS vertical dilution of precision (VDOP)
Fc9-type-16-icon.png Data Source
Injected GPS source for UTC time and date
Fc9-conn-icon.png Simulations
