Author
Matrix TSL
Version
1.0
Category
Comms: System
IO Expander component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
- BYTE
ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE
PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Pin
Port pin to read. Range: 0-7
- BYTE
WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
Value to output on the selected pin. Range: 0-1
WritePort
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE
Port
0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
Value to write. Range 0-255
ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE
PortA
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE
Address
Register address to write to. Range: 0-15
- BYTE
SetAddress
Allows the slave address to be overridden to allow multiple modules to be controlled using a single component.
- BYTE
Address
Range: 0-7
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE
Address
- BYTE
Value
Value to write. Range: 0-255
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
Use Reset
Simulations
API
