Component: Humidity (EBM016) (EBM Modules)
Revision as of 13:30, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C - as used by the Matrix e-block module EBM016. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
This example reads the temperature and humidity levels from the sensor and displays the readings on the LCD.
FC6 Icon.png EBM016 Example
Fc9-comp-macro.png GetTemperatureReal
Return temperature reading as a float value in degrees C
Fc9-comp-macro.png GetTemperatureData
Returns the raw register pair value
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
Fc9-comp-macro.png GetHumidityData
Fc9-comp-macro.png Initialise
Initialises the component ready for I2C communications
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Comms
