Component: Visi (4DSystems) (Comms: System)
Revision as of 13:32, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: System
Visi (4DSystems) component
A way of interacting with the VISI interface designed by 4D systems. VISI firmware must be pre-loaded onto the SD card connected to the display to allow everything to work correctly.
These examples are designed to work with a 4D systems display pre-programmed with the VISI Genie runtime files. These files are also included in the example archives to allow you to easily replicate the project.
The 4D display can either be connected to the PC running Flowcode using the 4D USB cable or connected to an embedded Microcontroller using a hardware or software UART. If you are using the Flowcode simulation to communicate with the Visi component then be sure to set the Visi COM port property to the COM port assigned by Windows to the 4D USB Cable.
The Console window should also show some helpful information to aid in debugging any problems.
The first example demonstrates a simple rocker switch Visi component. FC6 Icon.png RockerSwitch The second example demonstrates controlling the colour of an RGB LED using the Visi colour picker component. FC6 Icon.png ColourPicker
Fc9-comp-macro.png VisiWriteString
Writes a string to a specific Visi object. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE StringIndex
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png VisiWriteObject
Writes a value to a specific Visi object. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE ObjectID
Fc9-u8-icon.png - BYTE ObjectIndex
Fc9-u16-icon.png - UINT Value
Fc9-comp-macro.png ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
Fc9-u8-icon.png - BYTE NewBaud
Fc9-comp-macro.png VisiReceive
Waits for an incoming Visi Report Object or Report Event to be sent from the display. A detected incoming message returns 0 and can be read using the VisiReadByteFromMessage macro.
Fc9-comp-macro.png VisiWriteContrast
Updates the display contrast. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE Contrast
Range 0-15, 0=Backlight Off
Fc9-comp-macro.png VisiWriteVolume
Updates the display volume. Returns 0 for a succesful write operation.
Fc9-u8-icon.png - BYTE Volume
Range 8-127
Fc9-comp-macro.png VisiReadByteFromMessage
Reads a byte from a succesful VisiReceive macro. Index: 0=Command, 1=ObjectID, 2=ObjectIndex, 3=ValueMSB, 4=ValueLSB
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png VisiReadObject
Reads the value from a specific Visi object. Returns 0 for a sucessful read. Use the VisiReadByteFromMessage macro to pull out the incoming data.
Fc9-comp-macro.png Initialise
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Label shown on the communications flasher component
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
