Component: LCD I2C (Backpack) ()
Revision as of 13:32, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.2
Category
LCD I2C (Backpack) component
Standard alphanumeric LCD based on a standard I2C control bus. Usually using either a PIC device or Microchip IO expander IC.
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png BacklightControl
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Fc9-u8-icon.png - BYTE direction
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-comp-macro.png SetI2CAddress
Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
New I2C Device Address excluding R/W bit - Range 0 - 127
Fc9-type-21-icon.png LCD Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-type-7-icon.png Use Backlight
Controls if the backlight is controlled as part of the main data routine or if it is handled separately.
Fc9-type-16-icon.png API
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Allows the communications to be simulated via an injector component.
