Component: GLCD (ILI9488) (Graphical Color)
Revision as of 13:33, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Color
GLCD (ILI9488) component
Graphical display component designed to work with the ILI9488 controller IC Based on the ILI9488 16-bit colour graphical controller IC. Supports Serial, 8-bit and 16-bit interface modes.
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png LCD_Write_Reg
Fc9-u8-icon.png - BYTE data
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png LCD_Write_Data8
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-type-7-icon.png Flip X
Flips the horizontal display axis in hardware.
Fc9-type-7-icon.png Flip Y
Flips the vertical display axis in hardware.
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Display Method
Fc9-type-16-icon.png Connection Type
Fc9-type-5-icon.png Write (WR)
Fc9-type-5-icon.png Read (RD)
Fc9-type-7-icon.png Toggle CS
Allows the CS pin to be toggled by the component when communicating with the display. No - Allows for better performace, the display is always enabled Yes - Allows for the display pins to be multiplexed with other functionality without the risk of display corruption
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Reg Select (D/C)
Fc9-type-7-icon.png Use Ports
Allows the 8-bit or 16-bit data to be controlled using 8-bit ports. Yes - Ports will be used allowing for better data rates No - individual I/O pins will be used allowing for better flexibility
Fc9-type-5-icon.png Data0
Fc9-type-5-icon.png Data1
Fc9-type-5-icon.png Data2
Fc9-type-5-icon.png Data3
Fc9-type-5-icon.png Data4
Fc9-type-5-icon.png Data5
Fc9-type-5-icon.png Data6
Fc9-type-5-icon.png Data7
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-7-icon.png Use Backlight Pin
Fc9-type-5-icon.png LED
Fc9-conn-icon.png Simulations
