Component: GLCD (ST7920) Parallel (Graphical Monochrome)
Revision as of 13:33, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.4
Category Graphical Monochrome
GLCD (ST7920) Parallel component
Graphical display component designed to work with the ST7920 ype monochrome displays. Transfers data using an 8-bit digital data bus.
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Write_Data
Fc9-u8-icon.png - BYTE data
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Display Method
Fc9-type-16-icon.png Data Mode
Fc9-type-5-icon.png Data0
Data Pin 0
Fc9-type-5-icon.png Data1
Data Pin 1
Fc9-type-5-icon.png Data2
Data Pin 2
Fc9-type-5-icon.png Data3
Data Pin 3
Fc9-type-5-icon.png Data4
Data Pin 4
Fc9-type-5-icon.png Data5
Data Pin 5
Fc9-type-5-icon.png Data6
Data Pin 6
Fc9-type-5-icon.png Data7
Data Pin 7
Fc9-type-5-icon.png Reset
Reset pin
Fc9-type-5-icon.png RS
Fc9-type-5-icon.png Enable
Enable pin used to clock data into the display
Fc9-type-5-icon.png RW
Read Write pin to set the display data mode
Fc9-conn-icon.png Simulations
