Component: Injector (API Digital Output) (Test Injectors)
Revision as of 15:38, 17 December 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Test Injectors
Injector (API Digital Output) component
Data injector to allow a physical digital output pin to be attached to a simulated component. The component will forward any output state changes through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png RxByteCount
Returns the number of bytes currently sat in the receive buffer.
Fc9-comp-macro.png TxByte
Fc9-u8-icon.png - BYTE DataByte
Fc9-type-17-icon.png API Slave
Fc9-type-16-icon.png Number of Pins
Specifies the number of pins the component can monitor and control.
Fc9-type-5-icon.png Simulation I/O Pin
Pin monitored by the simulation
Fc9-type-21-icon.png SCADA Slave Pin
Pin used by the connected SCADA Slave hardware
Fc9-conn-icon.png Simulations
