Component: CAN (Internal, MCP2515) (Comms: Interface)
Revision as of 16:17, 7 January 2022 by Wiki bot (talk | contribs)
Version 2.10
Category Comms: Interface
CAN (Internal, MCP2515) component
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection or using an internal CAN peripheral if available on your device. Both methods will require a CAN driver IC like the MCP2551 to drive the CAN signals on the bus.
COMMSA
Internal CAN schematic
External CAN schematic
CAN Message Decoding
The CAN component works together with the injector component to allow you to decode a CAN message ID into a meaningful command.
Example File FC6 Icon.png CAN_Example1 When a key on the keypad is pressed the CAN components transmits a CAN packet.
The CAN packet is decoded by the injector component to give us a meaningful log on the console window.
High Level CAN Data Console
Low Level CAN Data Console
Reference from CAN Injector to ID decode file, $(srcdir) refers to the current project directory.
Demo CAN ID file File:CANID.csv
CAN Masks and Filters
How to work out which messages will be trapped by a particular mask/filter combination
Note that all values for message id's, masks and filters are numbers between 0x000 and 0x7FF.
Example 1
Mask0 = 0x0FF
Filter0 = 0x100
Filter1 = 0x050
In binary, this looks like:
Mask0 = 000 1111 1111
Filter0 = 001 0000 0000
Filter1 = 000 0101 0000
For the mask, a "1" signifies "check this bit" and a "0" means "ignore this bit"
So, these filters will accept the following messages ("x" = don't care)
Filter0 = xxx 0000 0000
Filter1 = xxx 0101 0000
i.e.
Filter0 = 0x000, 0x100, 0x200, 0x300, 0x400, 0x500, 0x600, 0x700
Filter1 = 0x050, 0x150, 0x250, 0x350, 0x450, 0x550, 0x650, 0x750
Example 2
Mask1 = 0x350
Filter2 = 0x200
Filter3 = 0x123
Filter4 = 0x3FF
Rewriting in binary:
Mask1 = 111 0101 0000
Filter2 = 010 0000 0000
Filter3 = 001 0010 0011
Filter4 = 111 1111 1111
Here, the mask will only check 4 bits and ignore the other 6. Here's what the filters will accept:
Filter2 = 010 x0x0 xxxx
Filter3 = 001 x0x0 xxxx
Filter4 = 111 x1x1 xxxx
They will actually trap a lot of messages (64 each!):
Filter2 = 0x200, 0x201, 0x202, ... 0x220, 0x221, ... 0x280, 0x281, ... 0x2A0, 0x2A1, ... 0x2AF
Filter3 = 0x100, 0x101, 0x102, ... 0x120, 0x121, ... 0x180, 0x181, ... 0x1A0, 0x1A1, ... 0x1AF
Filter4 = 0x750, 0x751, 0x752, ... 0x770, 0x771, ... 0x7D0, 0x7D1, ... 0x7F0, 0x7F1, ... 0x7FF
This second example is not very practical. In general, it is more logical to set the mask so that each filter accepts a consecutive range of messages.
As you can see, the mask determines which bits of the filters are actually looked at. Setting the mask to 0x000 will effectively mean that the filter will accept any incoming message. Also, the value of the mask directly relates to how many messages each filter will trap - i.e. 2^(number of '0' bits in the mask).
A useful way to use the mask would be to ignore the least significant bits. Lets say that you wanted the filters to accept 16 messages each - setting the Mask0 to 0x7F0 would achieve this. Then, setting the filters to the following:
Filter0 = 0x100
Filter1 = 0x110
would mean that the following messages are accepted:
Filter0 = 0x100, 0x101, 0x102, 0x103, 0x104, ... 0x10D, 0x10E, 0x10F
Filter1 = 0x110, 0x111, 0x112, 0x113, 0x114, ... 0x11D, 0x11E, 0x11F
Of course, for simple CAN applications you may wish to only accept one or two messages. Setting the mask to 0x7FF in this instance would mean that only the message ID specified by each filter would be accepted, e.g.
Mask1 = 0x7FF
Filter2 = 0x100
Filter5 = 0x200
This would mean that only messages 0x100 and 0x200 would be accepted into buffer 1.
Fc9-comp-macro.png ReadSwitches
Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
Fc9-comp-macro.png SetTxData
Assigns one of the outgoing transmit buffers with data ready to be sent.
Fc9-u8-icon.png - BYTE Buffer
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png SetRxMask
Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
Fc9-u8-icon.png - BYTE Mask
Specifies which receive mask to modify. Range: 0-1
Fc9-u32-icon.png - ULONG ID
The ID mask value you wish to use
Fc9-comp-macro.png GetRxData
Returns last received message data byte at position Index. Buffer parameter is currently ignored
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png GetRxIDHi
Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
Receive Buffer. Range 0-1
Fc9-comp-macro.png SetTxIDSimple
Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
Transmit buffer to load. Range: 0-2
Fc9-u16-icon.png - UINT ID
The ID value you wish to use. Range: 0-2047
Fc9-comp-macro.png SendBuffer
Transmits one of the transmit buffers which should have already been populated with an ID and data.
Specifies which transmit buffer to send
Fc9-comp-macro.png GetRxDataCount
Returns last received message data length. Buffer parameter is currently ignored
Fc9-comp-macro.png SetRxFilterID
sets the Filter Standard mode only (for V5 compatibility only)
Fc9-u8-icon.png - BYTE Filter
Specifies which filter to modify. Range: 0-5
Fc9-u8-icon.png - BYTE Hi
ID bits 3-10
Fc9-u8-icon.png - BYTE Lo
ID bits 0-2 stored in the upper 3 bits of the byte
Fc9-comp-macro.png GetRxIDLo
Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
Fc9-comp-macro.png SetRxMaskID
set the Mask Standard ID mode only (for V5 compatibility)
ID bits 3-10
Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
Specifies which receive filter to modify. Range: 0-5
The ID filter value you wish to use
Fc9-comp-macro.png SetTxIdent
Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
The ID or Extended ID value you wish to use. Range: 0-536870911
Fc9-comp-macro.png CheckRx
Checks to see if any messages are available for 'Buffer' specified
Send buffer: 0 to 1
Fc9-comp-macro.png GetRxIDSimple
Gets the Rx ID as a Integer Standard ID only 0-2047.
Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
Fc9-comp-macro.png ShowLEDs
Set LED state (External CAN only)
Fc9-u8-icon.png - BYTE led1
Controls LED 1. Range: 0-1
Fc9-u8-icon.png - BYTE led2
Controls LED 2. Range: 0-1
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-16-icon.png Channel
Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Fc9-type-16-icon.png Controller Osc
Fc9-type-16-icon.png Bus Rate
Data rate of the bus specified in thousand bits per second, Kbps.
Fc9-type-16-icon.png Sync Jump Width
Defines how far a resyncronisation may move the sample point
Fc9-type-16-icon.png Sample Point
Point in each bit period where the incoming data is sampled.
Fc9-type-16-icon.png ID Type
Switches between using Standard, or Standard and Extended CAN
Fc9-type-16-icon.png One Shot Mode
Disabled. Messages will reattempt transmission Enabled. Message will only attempt to transmit once
Fc9-type-16-icon.png CHANNEL
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png SS
Fc9-type-16-icon.png Prescale
Prescale option selector
Data bit read sample point
Fc9-type-16-icon.png Config Delay
Fc9-type-5-icon.png TX Pin
Internal CAN TX Pin
Fc9-type-16-icon.png TX Remap
Internal CAN Tx Remap Pin
Fc9-type-5-icon.png RX Pin
Internal CAN Rx Pin
Fc9-type-16-icon.png RX Remap
Internal CAN Rx Remap Pin
Fc9-type-14-icon.png Message ID
TX Buffer 0 Message Identifier
Fc9-type-14-icon.png Length
TX Buffer 0 Number of data bytes
Fc9-type-14-icon.png D0
TX Buffer 0 Data Byte 0
Fc9-type-14-icon.png D1
TX Buffer 0 Data Byte 1
Fc9-type-14-icon.png D2
TX Buffer 0 Data Byte 2
Fc9-type-14-icon.png D3
TX Buffer 0 Data Byte 3
Fc9-type-14-icon.png D4
TX Buffer 0 Data Byte 4
Fc9-type-14-icon.png D5
TX Buffer 0 Data Byte 5
Fc9-type-14-icon.png D6
TX Buffer 0 Data Byte 6
Fc9-type-14-icon.png D7
TX Buffer 0 Data Byte 7
TX Buffer 1 Message Identifier
TX Buffer 1 Number of data bytes
TX Buffer 1 Data Byte 0
TX Buffer 1 Data Byte 1
TX Buffer 1 Data Byte 2
TX Buffer 1 Data Byte 3
TX Buffer 1 Data Byte 4
TX Buffer 1 Data Byte 5
TX Buffer 1 Data Byte 6
TX Buffer 1 Data Byte 7
TX Buffer 2 Message Identifier
TX Buffer 2 Number of data bytes
TX Buffer 2 Data Byte 0
TX Buffer 2 Data Byte 1
TX Buffer 2 Data Byte 2
TX Buffer 2 Data Byte 3
TX Buffer 2 Data Byte 4
TX Buffer 2 Data Byte 5
TX Buffer 2 Data Byte 6
TX Buffer 2 Data Byte 7
Fc9-type-16-icon.png Settings
RX Buffer 0 Message Receive Mode
RX Buffer 1 Message Receive Mode
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Comms Flasher Identification Label
Fc9-type-7-icon.png Simulate SPI Comms
