Component: Input Digital (DSP)
Revision as of 16:18, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
DSP
Here is a basic example demonstrating how to pass a value into the DSP chain. FC6 Icon.png Delay The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
Fc9-comp-macro.png AddByte
Adds a single byte value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png AddFloatArray
Adds an array of float values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-f32-icon.png - FLOAT Data
Fc9-u16-icon.png - UINT Count
Fc9-comp-macro.png AddByteArray
Adds an array of byte values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-comp-macro.png AddLong
Adds a single long value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png AddInt
Adds a single integer value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png AddLongArray
Adds an array of long values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-comp-macro.png AddIntArray
Adds an array of integer values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Adds a single float value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Fc9-conn-icon.png Simulations
