Component: Output Digital (DSP)
Revision as of 16:18, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
DSP
Fc9-comp-macro.png GetIntArray
Returns an array of integer values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-u16-icon.png - UINT Data
Fc9-u16-icon.png - UINT Count
Fc9-comp-macro.png GetLongArray
Returns an array of long values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png GetFloatArray
Returns an array of float values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-f32-icon.png - FLOAT Data
Returns a float value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Returns a long value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-u32-icon.png - ULONG Return
Returns an integer value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-comp-macro.png GetByteArray
Returns an array of byte values from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-u8-icon.png - BYTE Data
Returns a byte value from the specified buffer. Auto increments the read location if the buffer size is greater than 1.
Fc9-type-16-icon.png Connect To
Fc9-type-7-icon.png Auto Scale
Automatically scale the buffer type to the output type Yes: Provide automatic scaling No: Transfer data as is, maybe truncated
Fc9-conn-icon.png Simulations
