Component: E block Helper (E blocks 1)
Revision as of 16:18, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.1
Category E-blocks 1
E-block Helper component
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. Specify which E-block your using and the component will give you options for the patch settings and display the connections required.
FREE
Example of E-blocks helper component being used to determine connections.
Fc9-type-16-icon.png E-block ID
E-block product ID
Fc9-type-10-icon.png E-block Name
Cosmetic name of the E-block to confirm you have the correct board.
Fc9-type-10-icon.png Bit 0
Port 1 Bit 0
Fc9-type-10-icon.png Bit 1
Port 1 Bit 1
Fc9-type-10-icon.png Bit 2
Port 1 Bit 2
Fc9-type-10-icon.png Bit 3
Port 1 Bit 3
Fc9-type-10-icon.png Bit 4
Port 1 Bit 4
Fc9-type-10-icon.png Bit 5
Port 1 Bit 5
Fc9-type-10-icon.png Bit 6
Port 1 Bit 6
Fc9-type-10-icon.png Bit 7
Port 1 Bit 7
Port 2 Bit 0
Port 2 Bit 1
Port 2 Bit 2
Port 2 Bit 3
Port 2 Bit 4
Port 2 Bit 5
Port 2 Bit 6
Port 2 Bit 7
Fc9-conn-icon.png Simulations
