Component: I2C Multiplexer (TCA9548A) (Comms: System)
Revision as of 16:19, 7 January 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
I2C Multiplexer (TCA9548A) component
An I2C multiplexing IC allowing up to 8 different I2C busses to be connected to a single I2C channel on your target microcontroller.
FREE
Here we have a simple example showing how to use the multiplexer to connect multiple of the same I2C sensor IC to the microcontroller.
The multiplexer IC is connected directly to the microcontroller I2C pins and up to 8 temp/humidity sensors are connected to the CH0-CH7 I2C pins of the multiplexer.
FC6 Icon.png I2C Multiplex Example
Fc9-comp-macro.png SelectChannel
Selects a single output channel to multiplex the I2C output to (0-7).
Range: 0-7
Fc9-comp-macro.png SetChannelMask
Allows a user determined number of channels to be connected to the I2C bus.
Fc9-u8-icon.png - BYTE Mask
Range: 0-255 / Bit0=CH0 EN / Bit1 = CH1 EN etc
Fc9-comp-macro.png Initialise
Startup the I2C bus ready for communications.
Fc9-type-16-icon.png Address Bits
Baud rate to be used
Fc9-type-16-icon.png Injector
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
