Component: MIAC Serial (MIAC: Addon Modules)
Revision as of 16:21, 7 January 2022 by Wiki bot (talk | contribs)
Author
Category MIAC: Addon Modules
MIAC Serial component
Serial Addon expansion module for MIAC System
FREE
Fc9-comp-macro.png UART_ReceiveChar
Fc9-u8-icon.png - BYTE Timeout
Fc9-comp-macro.png FAT_OpenFile
Fc9-comp-macro.png PWM_Enable
Enable the PWM on Channel 1 or 2
PWM Channel 1 or 2
Fc9-comp-macro.png MI2C_Send_Byte_Transaction
[[File:]] - Device_ID
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Data
Fc9-comp-macro.png SERIAL_ReceiveChar
Fc9-comp-macro.png FAT_Init
Fc9-comp-macro.png SERIAL_SendChar
Fc9-u16-icon.png - UINT Character
Fc9-comp-macro.png SPI_Uninit
Fc9-comp-macro.png MI2C_Stop
Fc9-comp-macro.png UART_SendString
Fc9-comp-macro.png MIAC_Module_SetData
Fc9-u8-icon.png - BYTE Count
Fc9-u8-icon.png - BYTE D0
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Fc9-comp-macro.png FAT_ScanCurrentFolder
Fc9-u16-icon.png - UINT idx
Fc9-u8-icon.png - BYTE type
Scan type
Fc9-comp-macro.png MIAC_Module_Init
Fc9-u16-icon.png - UINT CAN_ID
Fc9-comp-macro.png MIAC_Module_GetData
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png SPI_Init
Fc9-comp-macro.png FAT_AppendStringToFile
Fc9-comp-macro.png MIAC_Module_Message
Fc9-u16-icon.png - UINT CMD_ID
Fc9-comp-macro.png MIAC_Module_WR
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
Fc9-comp-macro.png MI2C_Restart
Fc9-comp-macro.png FAT_OpenFolder
Fc9-string-icon.png - STRING Folder
Fc9-comp-macro.png LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png SPI_Get_Char
[[File:]] - Return
Fc9-comp-macro.png UART_Initialize
Fc9-comp-macro.png FAT_MoveToNextFileSector
Fc9-u8-icon.png - BYTE force
force next sector
Fc9-comp-macro.png FAT_ReadByteFromScan
Fc9-comp-macro.png SPI_Send_Char
[[File:]] - Char
Fc9-comp-macro.png FAT_ReadFileLength
Fc9-comp-macro.png MI2C_Transmit_Byte
[[File:]] - Data
[[File:]] - Return
Fc9-comp-macro.png FAT_CreateFile
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png MI2C_Receive_Byte
[[File:]] - Last
Fc9-comp-macro.png MI2C_Init
Fc9-comp-macro.png PWM_Disable
Disable the PWM on Channel 1 or 2
PWM Channel 1 or 2
Fc9-comp-macro.png SERIAL_ReceiveString
Fc9-u8-icon.png - BYTE NumBytes
Fc9-comp-macro.png FAT_WriteFileSector
Fc9-comp-macro.png SERIAL_SendString
Fc9-comp-macro.png MI2C_Receive_Byte_Transaction
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Return
Fc9-comp-macro.png DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
Fc9-u8-icon.png - BYTE Terminal
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png FAT_ReadByteFromBuffer
Fc9-u16-icon.png - UINT address
Fc9-comp-macro.png MIAC_Module_GetAck
Fc9-u16-icon.png - UINT TimeOut
Fc9-comp-macro.png FAT_ReadFileSector
Fc9-comp-macro.png FAT_WriteByteToBuffer
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png SERIAL_Initialize
Fc9-comp-macro.png FAT_DeleteFile
Fc9-comp-macro.png AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
Terminal number to be read
Fc9-comp-macro.png Initialize
Forces a software reset on the module
Fc9-comp-macro.png UART_ReceiveString
Fc9-comp-macro.png PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
PWM Channel 1 or 2
Fc9-u8-icon.png - BYTE Duty
Duty cycle (8 bit value)
Fc9-comp-macro.png MI2C_Start
Fc9-comp-macro.png DigitalInput
Read the value of a terminal
Fc9-comp-macro.png UART_SendChar
Fc9-type-16-icon.png Module Type
Fc9-type-16-icon.png Module Address
Fc9-type-21-icon.png Period Overflow
Fc9-type-16-icon.png Prescaler
Fc9-type-15-icon.png Frequency (KHz)
Fc9-type-15-icon.png Period (uS)
Fc9-type-21-icon.png Baud Rate
Fc9-type-16-icon.png Data Bits
Fc9-type-16-icon.png Return Type
Fc9-type-16-icon.png Echo
Fc9-type-16-icon.png Flow Control
Fc9-type-16-icon.png Rate
Prescale option selector
Fc9-type-16-icon.png Clock Polarity
Fc9-type-16-icon.png Clock Phase
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-type-16-icon.png Slew Rate Control
Slew Rate Control Enabled or Disabled
Fc9-type-16-icon.png SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Fc9-conn-icon.png Simulations
