Component: Map Function (Storage)
Revision as of 16:21, 7 January 2022 by Wiki bot (talk | contribs)
Author medelec35
Version 2.0
Category Storage
Map Function component
The map function is intended to change one range of values into another range of values. For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
FREE
Fc9-comp-macro.png MapUlong
Map function for unsigned long type variables
Fc9-u32-icon.png - ULONG Value
Main variable used for map function
Fc9-u32-icon.png - ULONG InMin
Lowest input value
Fc9-u32-icon.png - ULONG InMax
Highest value input
Fc9-u32-icon.png - ULONG OutMin
Lowest value after conversion
Fc9-u32-icon.png - ULONG OutMax
highest value after conversion
Fc9-bool-icon.png - BOOL ClampMinMax
Clamp min & max so result does not go above or below set values. 0=No, 1=Yes
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png MapInt
Map function for signed int type variables
Fc9-s16-icon.png - INT Value
Fc9-s16-icon.png - INT InMin
Lowest input value
Fc9-s16-icon.png - INT InMax
Highest value input
Fc9-s16-icon.png - INT OutMin
Fc9-s16-icon.png - INT OutMax
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png MapFloat
Map function for floating point type variables
Fc9-f32-icon.png - FLOAT InMin
Lowest input value
Fc9-f32-icon.png - FLOAT InMax
Highest value input
Fc9-f32-icon.png - FLOAT OutMin
Fc9-f32-icon.png - FLOAT OutMax
Fc9-comp-macro.png MapLong
Map function for signed long type variables
Fc9-s32-icon.png - LONG Value
Fc9-s32-icon.png - LONG InMin
Lowest input value
Fc9-s32-icon.png - LONG InMax
Highest value input
Fc9-s32-icon.png - LONG OutMin
Fc9-s32-icon.png - LONG OutMax
Fc9-comp-macro.png MapUInt
Map function for unsigned int type variables
Fc9-u16-icon.png - UINT Value
Fc9-u16-icon.png - UINT InMin
Lowest input value
Fc9-u16-icon.png - UINT InMax
Highest value input
Fc9-u16-icon.png - UINT OutMin
Fc9-u16-icon.png - UINT OutMax
Fc9-comp-macro.png MapByte
Map function for byte type variables
Fc9-u8-icon.png - BYTE Value
Fc9-u8-icon.png - BYTE InMin
Lowest input value
Fc9-u8-icon.png - BYTE InMax
Highest value input
Fc9-u8-icon.png - BYTE OutMin
Fc9-u8-icon.png - BYTE OutMax
Fc9-conn-icon.png Simulations
