Component: Real Time Clock (MCP7940N) (Storage)
Revision as of 16:21, 7 January 2022 by Wiki bot (talk | contribs)
Category Storage
Real Time Clock (MCP7940N) component
Serial (I2C) Real Time Clock component for MCP7940N device. When used with a MIAC project this component gives access to the internal RTC (if fitted, depending upon model) and the component properties will be automatically configured.
STORAGE
Fc9-comp-macro.png SetTime
Sets the time from a string HHMMSS
Fc9-string-icon.png - STRING Time
Fc9-comp-macro.png GetTime
Returns the time as a string HHMMSS
Fc9-comp-macro.png ReadRegister
Read and return the value of the RTC register at the given address
Fc9-u8-icon.png - BYTE address
Fc9-comp-macro.png SetDate
Sets the date from a string DDMMYY
Fc9-string-icon.png - STRING Date
Fc9-comp-macro.png GetDate
Returns the date as a string DDMMYY
Fc9-comp-macro.png WriteRegister
Write the given data value to the RTC register at the given address
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png Initialise
Initialises the component ready for I2C communications
Fc9-type-16-icon.png API
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Simulations
