Component: Numeric Label (Indicators)
Revision as of 16:22, 7 January 2022 by Wiki bot (talk | contribs)
Category Indicators
Numeric Label component
Allows a numeric label to be displayed on the user panel. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
SCADA
Fc9-comp-macro.png DisplayAsReal
Displays a floating point value on the label with a confiiguarable number of decimal points
Real floating point value to display
Fc9-u8-icon.png - BYTE Precision
Number of decimal point values to show e.g. 2 = 0.00
Allows the user to manually specify the default colour of the foreground text.
Fc9-s32-icon.png - LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR, -1 for Transparent
Fc9-comp-macro.png DisplayAsInt
Displays an integer value on the label. Capable of displaying positive and negative values.
Fc9-s32-icon.png - LONG Value
Integer value to display
Fc9-comp-macro.png SetUnits
Allows the user to manually specify the units string that is appended to the end of the label.
Fc9-string-icon.png - STRING Units
Fc9-type-7-icon.png Show Title
Decides if the title is shown on the panel.
Fc9-type-10-icon.png Title Text
Specifies the title displayed on the panel.
Fc9-type-15-icon.png Title Scale
Specifies the size of the title on the panel, default 1.2
Fc9-type-2-icon.png Title Colour
Specifies the colour of the title text
Fc9-type-15-icon.png Title Offset
Distance above component center to draw the title
Fc9-type-15-icon.png Label Scale
Specifies the scale of the label text, default 1.0
Fc9-type-7-icon.png Show Units
Specifies if the unit text is appended to the end of the numeric value
Fc9-type-10-icon.png Unit Text
Optionally adds a unit label to the end of the displays string
Fc9-type-16-icon.png Colour Ranges
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Fc9-type-2-icon.png Numeric Colour
The label Text colour
Fc9-type-15-icon.png Min Value
The minimum value to meet the range condition ( >= )
Fc9-type-15-icon.png Max Value
The maximum value to meet the range condition ( < )
The label Text colour when in the specified range
Fc9-conn-icon.png Simulations
