Component: Property Manager (Storage )
Revision as of 16:22, 7 January 2022 by Wiki bot (talk | contribs)
Category Storage
Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
FREE
Fc9-comp-macro.png Save
Saves the registered property values to the config file.
Fc9-comp-macro.png Load
Loads the registered property values from the config file.
Fc9-comp-macro.png RegisterProperty
Registers a property to be saved or loaded
Fc9-string-icon.png - STRING PropertyVariable
Property variable exposed to the user, highlight property and variable is shown at the bottom of the window.
Fc9-type-20-icon.png Filepath
Sets the path of the file to write to. $(srcdir) default sets the path to be the same as the Flowcode project path.
Fc9-type-10-icon.png Filename
Fc9-type-7-icon.png Show Dialogue On Load
Forces the user to check if they are sure before loading saved values.
Fc9-type-7-icon.png Show Dialogue On Save
Forces the user to check if they are sure before overwriting previous values.
Fc9-conn-icon.png Simulations
