Component: Infrared (EBM020) (EBM Modules)
Revision as of 16:23, 7 January 2022 by Wiki bot (talk | contribs)
Category EBM Modules
Infrared component
The Infrared sensor board contains both an IR transmitter and receiver. The transmitter is enabled via a digital control signal and the receiver provides an analogue output. By enabling the transmitter and reading the variable voltage output of the receiver it is possible to measure the distance of a reflecting object in the region of 1cm to 10cm.
SENSORS
Sample program using the EBM020 - Infrared sensor.
Transmits a signal and determines distance from reflected value
FC6 Icon.png EBM020 Example
Fc9-comp-macro.png SetTxOff
Turns off the IR Transmitter
Fc9-comp-macro.png SetTxOn
Turns on the IR Transmitter
Fc9-comp-macro.png GetDistanceValue
Returns the calculated distance for the given ADC reading
Fc9-u8-icon.png - BYTE adc
Fc9-comp-macro.png GetADCValue
Gets the raw ADC input value for the IR receiver
Fc9-comp-macro.png Initialise
Initialise the component by loading the default calibration table
Fc9-type-6-icon.png Input ADC Channel
Analog input channel for the IR receiver
Fc9-type-5-icon.png Output Enable Pin
Pin used to control the IR Transmitter
Fc9-type-21-icon.png Point 1 ADC Value
The ADC value that would give the Point 1 Distance. If the ADC value is 0 the point is ignored.
Fc9-type-21-icon.png Point 1 Distance (mm)
The distance returned for an ADC reading given by Point 1 ADC value
Fc9-type-21-icon.png Point 2 ADC Value
Fc9-type-21-icon.png Point 2 Distance (mm)
Fc9-type-21-icon.png Point 3 ADC Value
Fc9-type-21-icon.png Point 3 Distance (mm)
Fc9-type-21-icon.png Point 4 ADC Value
Fc9-type-21-icon.png Point 4 Distance (mm)
Fc9-conn-icon.png Simulations
