Component: Temperature (LM75B) (Environmental)
Revision as of 16:24, 7 January 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temperature component
A digital temperature sensor based around the NXP LM75B chip.
SENSORS
Fc9-comp-macro.png ReadInt
Read double byte data from register at address
Fc9-u8-icon.png - BYTE address
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadFloat
Reads the temperature value as a float
Fc9-comp-macro.png WriteByte
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png WriteInt
Fc9-u16-icon.png - UINT data
Fc9-comp-macro.png ReadByte
Read a single byte at a specific address from the chip's internal memory.
Fc9-comp-macro.png Uninit
Uninitialise and release resources
Fc9-comp-macro.png Initialise
Initialise to default of 11 bit resolution
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Comms
Fc9-type-15-icon.png Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Fc9-type-15-icon.png Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Fc9-type-21-icon.png Scale divisions
Number of numbered divisions shown on the thermometer scale.
Fc9-type-16-icon.png I2C Data
Set whether the I2C data is displayed as decimal or hexadecimal numbers.
