Component: RFID (Sparkfun Quiic / ID 12LA) (15209) (Wireless)
Revision as of 16:25, 7 January 2022 by Wiki bot (talk | contribs)
Category Wireless
RFID (Sparkfun Quiic / ID-12LA) component
Provides functions to drive the Sparkfun Quiic RFID reader module (ID-12LA). Allowing access to read 125KHz RFID tags. Suitable for applications such as tracking, logging or access control.
FREE
Fc9-comp-macro.png ChangeI2CAddress
Allows the I2C Device address to be changed which in turn allows more then one RFID reader to sit on the same physical I2C bus. Returns 1 if succesful.
Fc9-u8-icon.png - BYTE NewAddress
Range: 7 to 120 or 0x07 - 0x78
Fc9-comp-macro.png RemoveCurrentTag
Removes the current Tag ID from the known tag storage.
Fc9-comp-macro.png StoreCurrentTag
Stores the current detected tag as a known tag storage Returns true if the tag has been stored or false if there is no remaining room
Fc9-comp-macro.png GetTagString
Gets the tag ID returned as a string. Must be called after CheckForTag has returned true. String variable should be at least 13 characters long.
Fc9-comp-macro.png RemoveTagID
Removes a specific 6-byte tag ID from the known tag storage
Fc9-u8-icon.png - BYTE ID
Array of 6 bytes containing tag ID
Fc9-comp-macro.png GetTimeMS
Gets the time in milliseconds since the tag was read by the module. Must be called after CheckForTag has returned true.
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png StoreTagID
Stores a specific 6-byte tag ID into the known storage Returns true if the tag has been stored or false if there is no remaining room
Fc9-comp-macro.png GetTimeS
Gets the time in seconds since the tag was read by the module. Must be called after CheckForTag has returned true.
Fc9-comp-macro.png CheckForTag
Checks to see if a tag has been detected by the module. Returns 1 if tag has been detected. Tag ID and Time since read can be accessed using GetTag and GetTime macros.
Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png IsKnownID
Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory.
Fc9-comp-macro.png Initialise
Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored.
Fc9-type-21-icon.png Device Address
External device address used to communicate with the module. Default 125 or 0x7D
Fc9-type-21-icon.png Stored Tag Count
Number of tags IDs to store as valid IDs for use with IsKnownID. For example max number of users for a door entry system. Each stored ID requires 6 bytes of RAM memory. Max 42.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
