Component: Circular Buffer (16 bit) (Storage)
Revision as of 16:25, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.5
Category Storage
Circular Buffer (16-bit) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific 16-bit values.
STORAGE
Fc9-comp-macro.png WaitForValues
Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
Fc9-u16-icon.png - UINT Values
Fc9-u8-icon.png - BYTE NumValues
Number of values to try and look for
Fc9-u8-icon.png - BYTE RemoveContent
0=Leave the buffer contents untouched, 1=Remove values as you go
Fc9-u16-icon.png - UINT Timeout
Max amount of time to wait in milliseconds before returning 0=WaitForever
Fc9-comp-macro.png GetNumberValues
Returns the number of valid 16-bit data values currently stored inside the buffer.
Fc9-comp-macro.png PeekData
Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty.
Fc9-comp-macro.png PutData
Add a 16-bit value to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png LookForValues
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
The number of values you wish to try and match
0=Leave data alone, 1=Remove data from buffer
Fc9-u8-icon.png - BYTE ResetFind
0=Continue the find from the last operation, 1=Start again
Fc9-comp-macro.png GetData
Reads the next available 16-bit value from the circular buffer, Returns the default value if the buffer is empty.
Fc9-comp-macro.png FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
Fc9-comp-macro.png GetIndexedValue
Gets the value of a single 16-bit value at a known location in the buffer. Leaves the buffer contents and pointers untouched.
Fc9-u16-icon.png - UINT address
Sets the number of byte elements inside the circular buffer. The maximum number of bytes that can be stored at any one time is this number minus 1.
Fc9-type-16-icon.png Storage Type
When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Fc9-type-16-icon.png Memory Type
Fc9-type-21-icon.png Default Return Data
Specifies the value returned by the receive function when there is no data held in the buffer
Fc9-conn-icon.png Simulations
