Component: GLCD (EB043 v2) (E blocks 1)
Revision as of 16:28, 7 January 2022 by Wiki bot (talk | contribs)
Version 1.4
Category E-blocks 1
GLCD (EB043 v2) component
Graphical display component designed to work with the legacy version 2 EB043 E-blocks.
DISPLAYS
EB043 v2 gLCD Example File FC6 Icon.png EB043 Example Example should show the following on the display on the panel and on the hardware.
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Display Method
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png A0
Data / Instruction pin connection
Fc9-conn-icon.png Simulations
