Component: Coupling (Mechatronics)
Revision as of 16:29, 7 January 2022 by Wiki bot (talk | contribs)
Category Mechatronics
Coupling component
A simple component to couple together two rotating shafts. An essential component when working with motors, gearboxes, encoders and other rotational systems.
MECHATRONICS
Fc9-comp-macro.png Rotate
Simulation macro called behind the scenes by motor components when rotating.
Fc9-f32-icon.png - FLOAT Angle
Fc9-type-15-icon.png Width
Fc9-type-15-icon.png Height
Fc9-type-15-icon.png Depth
Fc9-type-17-icon.png Input
Input connection for example a motor or other active component or primitive.
Fc9-type-17-icon.png Output
Output connection for example a primitive or a component such as a linear slide or gearbox.
Fc9-type-15-icon.png Input Offset
Distance along the shaft from the center of the input object to the center of the coupling.
Fc9-type-15-icon.png Output Offset
Distance along the shaft from the center of the coupling to the center of the output object.
Fc9-type-15-icon.png Output Translation X
Distance along the X axis from the center of the coupling to the center of the output object.
Fc9-type-15-icon.png Output Translation Y
Distance along the Y axis from the center of the coupling to the center of the output object.
Fc9-conn-icon.png Simulations
