Component: CNC Machine (Scenarios)
Revision as of 16:29, 7 January 2022 by Wiki bot (talk | contribs)
Author Matrix
Category Scenarios
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
MODELS
CNC Machine Scenario
Fc9-comp-macro.png ZAxisMovement
Moves the components Z axis by 0.01mm. Direction determines direction 1= Down 0 = Up If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
Fc9-u8-icon.png - BYTE Direction
Assign a value of 1 or 0. 1 will move the component down. 0 will move it up.
Fc9-comp-macro.png Drill_Speed
Will cause the drill to rotate according to the speed. If no speed is set it will stay static.
Fc9-f32-icon.png - FLOAT DrillSpeed
Speed of the Drill. 0=Stopped
Fc9-comp-macro.png MoveToXYZ
Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation.
Fc9-f32-icon.png - FLOAT X
Fc9-f32-icon.png - FLOAT Y
Fc9-f32-icon.png - FLOAT Z
Fc9-comp-macro.png YAxisMovement
Moves the components Y axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
Assign a value of 1 or 0. 1 will move the component right. 0 will move it left.
Fc9-comp-macro.png HomeMachine
Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0.
Fc9-comp-macro.png XAxisMovement
Moves the components X axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
Assign a value of 1 or 0. 1 will move the component forward. 0 will move it up.
Fc9-comp-macro.png ResetCoordinates
Resets the coordinates to the home position 0,0,0.
Fc9-comp-macro.png Initialise
Enables the three motors within the component allowing for movement when any of the Axis macros are called.
Fc9-conn-icon.png Simulations
