Component: 7Segment (74HC595) (Segment)
Category Segment
7Segment component
Seven segment display using 74HC595 serial to parallel shift register. Requires three standard output pins to drive the shift register. Shift registers can be chained together to drive up to six individual 7-segment displays. The connections currently are fixed:
QA = SegmentA
QB = SegmentB
QC = SegmentC
QD = SegmentD
QE = SegmentE
QF = SegmentF
QG = SegmentG
QH = SegmentDP
BASICIO
Fc9-comp-macro.png ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
Fc9-u8-icon.png - BYTE Value0
The number value to set the digit to (0...15), 16=Clear
Fc9-u8-icon.png - BYTE Value1
Fc9-u8-icon.png - BYTE Value2
Fc9-u8-icon.png - BYTE Value3
Fc9-u8-icon.png - BYTE Value4
Fc9-u8-icon.png - BYTE Value5
Fc9-u8-icon.png - BYTE DecimalPoint
Bit field containing the states of the decimal points.
Fc9-comp-macro.png ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
Fc9-u8-icon.png - BYTE Digit
Which of the digits to change. (0...5)
Fc9-u8-icon.png - BYTE Segments
The binary segment value to display, 0b1 = Lit, 0b0 = Not Lit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
Whether to show the decimal point.
Fc9-type-16-icon.png Number 7Segs
Fc9-type-16-icon.png Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Fc9-type-7-icon.png Show Seg Labels
Show segment name labels overlayed over the component.
Fc9-type-1-icon.png LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Fc9-type-1-icon.png Body Color
Color of the plastic casing containing the LEDs.
Fc9-type-1-icon.png Label Color
Color for the optional LED segment labels.
Fc9-type-5-icon.png Data Pin
Data Pin connection to the first 74HC595 chip
Fc9-type-5-icon.png Clock Pin
Clock Pin connection to all the 74HC595 chips
Fc9-type-5-icon.png Latch Pin
Latch Pin connection to all the 74HC595 chips
Fc9-conn-icon.png Simulations
