Component: LED Array (PCB) ()
Author | Matrix |
Version | 1.1 |
Category |
LED Array (PCB) component
An LED matrix made up of standard PCB mount 5mm LEDs.
BASICIO
Properties |
Count |
The number of LEDs in the array from 1 to 8. | |
Connections |
Output Mode |
Choose a single port for all LEDs, or to allocate them to arbitrary pins. | |
File:Fc9-type-19-icon.png | Port |
Polarity |
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF | |
Simulations |
Alignment |
Which 3D axis to align the copies along. | |
Spacing |
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs. | |
Reverse |
Reverse the direction of the LEDs. | |
Show |
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below. | |
Property |
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text. | |
Label Position |
Whether to display the pin labels next to each LED | |
LED color |
The on colour for the LEDs, the off colour is calculated automatically from this. | |
Label color |
Color of the pin labels. |
