Component: Potentiometer (Colour) ()
Revision as of 15:47, 14 February 2022 by MartinW (talk | contribs) (→‎Examples)
Version 1.3
Category
Potentiometer (Colour) component
Potentiometer with black plastic knob with coloured cap. Cap and pointer colours can be changed in component properties.
FREE
FC6 Icon.png Potentiometer Example
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Simulations
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Cap Color
Colour of the knob cap.
Fc9-type-1-icon.png Pointer Color
Colour of the knob pointer.
