Component: Potentiometer (Trimmer) ()
Revision as of 15:49, 14 February 2022 by MartinW (talk | contribs) (→‎Examples)
Version 1.4
Category
Potentiometer (Trimmer) component
Trim Pot for 0.1mm pitch PCB. With finger dial knob. Pointer colour can be changed from component properties.
BASICIO
FC6 Icon.png Potentiometer Example
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Simulations
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
