Component: Colour GLCD (BL0157) (E-blocks 2)
Revision as of 12:09, 4 March 2022 by MartinW (talk | contribs) (→‎Examples)
Version 1.6 (Release)
Category E-blocks 2
Image Colour GLCD (BL0157) component
Graphical display component designed to work with the BL0157 E-block. Based on the ILI9163C 16-bit colour graphical controller IC.
You can use component macros in flowcode 8 to draw various shapes on the colour GLCD such as a circle, an ellipse, a line and a rectangle. There are also macros to turn the backlight on or off, and to print a string of characters or a decimal number on the screen of the GLCD. As it is a ‘colour’ GLCD, you can set the background or foreground colour by inputting values from 0-255 for red, green and blue, in order to create almost any colour in the world. Before the GLCD can take information in, you need to initialise it with a component macro.
Make sure all connections in flowcode are connected to the correct port and pins, the port should correspond to the port that the colour GLCD is connected to on your E-blocks 2 upstream board.
A simple example that shows how to use some common functions.
FC6 Icon.png BL0157 Example
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on.
Switching the backlight on and off at high speed allow the light to be dimmed.
This macro has no parameters
INT Number
UINT X
UINT Y
BYTE Font
BYTE Transparent
DrawLine
UINT X1
UINT Y1
UINT X2
UINT Y2
Plot
UINT X1
UINT Y1
DrawEllipse
UINT X
UINT Y
UINT XRadius
UINT YRadius
BYTE Transparent
BYTE Solid
FastPlot
Sets a pixel with the current foreground colour at current pixel location.
Not compatible with orientations other than 0.
SetDisplayOrientation
BYTE Orientation
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off.
BPlot
UINT X1
UINT Y1
Window
Specifies a full screen or sub window of pixels to draw.
Useful when used with the FastPlot function to draw bitmaps at high speed.
BYTE X1
BYTE Y1
BYTE X2
BYTE Y2
Print
<- STRING Str
This parameter may be returned back to the caller
UINT X1
UINT Y1
BYTE Font
BYTE Transparent
ClearDisplay
SetBackgroundColour
BYTE Red
BYTE Green
BYTE Blue
DrawCircle
UINT X
UINT Y
UINT Radius
BYTE Transparent
BYTE Solid
SetForegroundColour
BYTE Red
BYTE Green
BYTE Blue
DrawRectangle
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE Transparent
BYTE Solid
Simulation macro reference
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Colour Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Data
This property is of type Single digital pin and can be referenced with the variable name data_pin.
Data pin connection
Clock
This property is of type Single digital pin and can be referenced with the variable name clock_pin.
Clock pin connection
Chip Select
This property is of type Single digital pin and can be referenced with the variable name chip_sel_pin.
Chip select pin connection
A0
This property is of type Single digital pin and can be referenced with the variable name a0_pin.
Reset
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
Reset pin connection
LED
This property is of type Single digital pin and can be referenced with the variable name led_pin.
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
