Component: LCD I2C (Backpack) ()
Version 2.2
Category
LCD I2C (Backpack) component
Standard alphanumeric LCD based on a standard I2C control bus. Usually using either a PIC device or Microchip IO expander IC.
DISPLAYS
A simple example that shows how to use some common functions.
FC6 Icon.png Backpack LCD Example
If the display is not showing the expected characters, the I2c address or contrast could be wrong.
It's best to keep the jumper connected since the backlight is enabled by default.
The correct I2C address can be determined by using an FC6 Icon.png IC2 Address Sniffer
The I2C address to use is the one within the first set of square brackets.
For example, with my backpack display, the correct address to use is 0x3F [63]:
The other two Addresses i.e. 0x56 [86] and 0x68 [104] is for my 24C32 EEPROM and DS3231 RTC respectively.
Note The I2c addresses scan will repeat every 5seconds.
The sniffer will send data to your PC via UART to USB.
The Arduino range and clones will have it built-in.
More details on I2C can be found here,
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png BacklightControl
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Fc9-u8-icon.png - BYTE direction
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-comp-macro.png SetI2CAddress
Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
New I2C Device Address excluding R/W bit - Range 0 - 127
Fc9-type-21-icon.png LCD Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-type-7-icon.png Use Backlight
Controls if the backlight is controlled as part of the main data routine or if it is handled separately.
Fc9-type-16-icon.png API
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Allows the communications to be simulated via an injector component.
