Component: Lookup tables (Storage)
Revision as of 13:18, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.7
Category Storage
Lookup tables component
A lookup-table component allowing an easy way to place arrays of static data into ROM memory. The LUT data is accessed directly allowing very low overhead when collecting the data.
Please click here for the component source code: [../../componentsource/FC_Comp_Source_LUT.fcfx FC_Comp_Source_LUT.fcfx]
A look up table component is useful when including data into a program which may not be linear and therefore hard to calculate.
One example of this is a sine wave or working out a temperature based on the resistance of a thermistor.
For a simple example lets say we want to store a sine wave on board the microcontroller.
First of all we use Excel to generate the data for a sine wave to do this we work out the angles in degrees we want to reproduce, then convert the degrees to radians and then generate the Sine wave for the angle. the angle returned will be between -1 and 1 so we need to convert this to fit into the microcontroller's memory. The most efficient way is to store the value as a byte which means scaling up the output to 0 - 255 and removing the real portion of the number to give integer values.
File:SineWaveLUT.xlsx
Then using the file -> Save as menu in Excel we can export the data as a raw .CSV file.
File:SineWaveLUT.csv
The line in the CSV file we are interested in is the Integer Offset Data. We can then copy and paste this data into the integer property of the look up table component.
In this example Flowcode file we display the LUT data onto a graphical LCD display FC6 Icon.png LUT Here is what you should expect to see on the glcd after running the simulation.
Fc9-comp-macro.png GetFloats
Gets the float LUT
Fc9-f32-icon.png - FLOAT Dest
Fc9-comp-macro.png GenerateCache
Generates the C code for the arrays so it does not need to be done at compile time
Fc9-comp-macro.png GetIntCount
Gets the number of int LUT entries
Fc9-comp-macro.png ClearInts
Clear all int LUT values
Fc9-comp-macro.png GetFloatCount
Gets the number of float LUT entries
Fc9-comp-macro.png GetIntBits
Gets the number of bits-per-int in the LUT
Fc9-comp-macro.png SetIntBits
Sets the size of an int LUT entry
Fc9-u8-icon.png - BYTE Bits
Fc9-comp-macro.png GetFloatBits
Gets the number of bits-per-float in the LUT
Fc9-comp-macro.png ClearFloats
Clear all float LUT values
Gets a float from the LUT
Fc9-u32-icon.png - ULONG Index
Fc9-comp-macro.png GetInts
Gets the int LUT
Fc9-u32-icon.png - ULONG Dest
Fc9-comp-macro.png GetLUTCount
Gets the number of individual data entries stored in the LUT.
Gets an integer from the LUT
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetFloatBits
Sets the size of a float LUT entry
Fc9-comp-macro.png AddInt
Int to add to the int array
Fc9-u32-icon.png - ULONG Value
Fc9-comp-macro.png AddFloat
Add a float to the floating point LUT
Floating point values
Fc9-type-16-icon.png Storage Type
Controls the data type stored by the component.
Fc9-type-16-icon.png Storage Sign
Controls if the integer numbers are allowed to be negative. Unsigned = Numbers are positive only. Signed = Numbers can be positive and negative.
Fc9-type-11-icon.png Integers
Comma seperated integer data which is used to create the C code which is inserted into the ROM.
Fc9-type-21-icon.png Num Values
Fc9-type-7-icon.png Embed Into C
Flag to decide if code should be generated to C or not If this is false then the LUT is simulation only
Fc9-conn-icon.png Simulations
