Component: I2S Master/Slave ESP32 (Comms: Interface)
Revision as of 17:18, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Interface
I2S Master/Slave ESP32 component
Provides access to the onboard inter-IC sound (I2S) peripheras allowing for simple digital audio input and output.
FREE
Fc9-comp-macro.png Stop
Stops the I2S audio stream
Fc9-comp-macro.png Read
Wait timeout ticks to receive length number of samples, returns samples received. 24 and 32-bit data must be split into two integer values per sample.
Fc9-s16-icon.png - INT Data
Data array to populate with incoming data
Max number of samples to try and receive
Fc9-u16-icon.png - UINT Timeout
Max number of ticks to wait for incoming samples
Fc9-comp-macro.png CheckQueue
Checks the I2S Event queue for a DMA Buffer full or empty event. For an output returns true when there is an empty DMA buffer available. For an input return true when there is a full DMA buffer available.
Fc9-comp-macro.png Write
Wait timeout ticks to send length number of samples, returns samples sent 24 and 32-bit data must be split into two integer values per sample.
Data array containing outgoing data
Max number of samples to try and send
Max number of ticks to wait for space in the outgoing buffer
Fc9-comp-macro.png Start
Starts the I2S audio stream, auto started by the initialise function.
Fc9-comp-macro.png Initialise
Configures the I2C peripheral ready for data.
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png Clock Pin
I2S Clock Pin
Fc9-type-5-icon.png Serial Data Pin
I2S Serial Data (SD) Pin
Fc9-type-5-icon.png Word Select Pin
I2S Word Select (WS) Pin
Fc9-type-16-icon.png Mode
Configures if the I2S peripheral is a master or slave on the bus.
Fc9-type-16-icon.png Data Direction
Controls if the I2S data is coming in or out of the microcontroller
Fc9-type-16-icon.png Audio Channels
Number of distinct audio channels in the data stream
Fc9-type-21-icon.png Sample Rate
Audio sample rate in Hz
Fc9-type-16-icon.png Data Bits
Nmber of bits in each audio sample
Fc9-type-21-icon.png DMA Buffer Count
I2S DMA Buffer Count
Fc9-type-21-icon.png DMA Buffer Size
I2S DMA Buffer Size
Fc9-conn-icon.png Simulation
