Author
Matrix TSL
Version
1.0
Category
Audio Output
DFPlayer (MP3 / WAV) component
A small module capable of streaming MP3 and WAV audio files from a micro SD card. Controlled via a serial UART connection to the microcontroller.
COMMSA
No Examples here yet
PausePlayResetStop
Allows the current playing track to be paused, restarted or reset
- UINT
Mode
0=Pause, 1=Play, 2=Reset, 3=Stop
SendCommand
Sends a command to the DFPlayer module
- BYTE
Command
Command code byte
- BOOL
Feedback
Collect feedback byte: Range 0-1
- UINT
Parameter
16-bit Parameter
IsReplyAvailable
Checks to see if new data has been received from the module. Returns true when new data is available. Collect the data using the GetReplyByte macro.
- BOOL
SetVolume
Sets the volume level for the module
- BYTE
Volume
Range: 0 (min) - 30 (max)
SetEQ
Sets the equaliser mode for the module
- BYTE
EQMode
Range: 0-5 0=Normal, 1=Pop, 2=Rock, 3=Jazz, 4=Classic, 5=Bass
GetError
Checks for any errors and returns the error code. 1=ModuleBusy, 2=SleepMode, 3=SerialError, 4=ChecksumError, 5=TrackOutOfScope, 6=TrackNotFound, 7=InsertionError, 8=SDFail, 10=Sleep
- BYTE
WhilePlaying
Blocking function that waits for module to stop being busy. Returns true if the module is still busy and the timeout period has passed.
- UINT
Timeout
Number of milliseconds to wait, 0=WaitForever
- BOOL
IsPlaying
Checks to see if the last played track is still playing
- BOOL
GetReplyByte
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code.
- BYTE
Index
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB
- BYTE
SkipTrack
Jump to the next or previous track
- BOOL
Direction
0=Next, 1=Previous
PlayTrack
Plays track from the selected folder. MP3 & Advert folder track numbers should be 4 characters long e.g. 0001 any name.mp3, Other folder track numbers should be 3 characters long e.g. 001 Any name.mp3, Root the Track played in placement order.
- BYTE
Directory
0=Root, 1=Folder "01" - 99=Folder "99", 100=MP3, 101=Advert
- UINT
Track
Track number 1="001*.MP3" / "0001*.MP3", 100="100*.MP3" / "0100*.MP3"
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros.
Baud Options
TX
RX
Use Busy Pin
Controls if we are monitoring the busy pin or not. Used by the IfBusy component macro.
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
API
Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
