Component: Output CSV (DSP)
Revision as of 17:19, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Output CSV component
Allows the values from a buffer to be output directly into a .CSV format file. Either a value at a time or as an array.
DSP
Fc9-comp-macro.png CloseFile
Closes a file
Fc9-comp-macro.png WriteArray
Writes a buffer of values from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
Fc9-comp-macro.png OpenFile
Opens a file ready for writing. Returns 1 if file opened OK. Automatically called by the WriteValue/WriteArray macros with the default values set by the component properties if not already called by the program.
Filename, must be an 8.3 formatted filename in embedded.
Fc9-bool-icon.png - BOOL ExistingData
0=KeepAndAppend, 1=Clear
Fc9-comp-macro.png WriteValue
Writes a single value from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro.
Fc9-type-16-icon.png Connect To
Fc9-conn-icon.png CSV File
Fc9-type-17-icon.png FAT Component
Points to the FAT filesystem component to allow access to file system and embedded SD card.
Fc9-type-10-icon.png Filename
Name of the file to write DSP data to. Requires an 8.3 file name for use with embedded file component.
Fc9-type-16-icon.png Layout
Fc9-type-16-icon.png Existing Data
Decides what to do when opening a file that already exists.
