Component: Output Digital Pin (DSP)
Revision as of 17:19, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Output Digital Pin component
Allows the values from a buffer to be passed directly to a digital output pin based on a defined threshold.
DSP
Fc9-comp-macro.png SetPin
Takes the value from the connected DSP buffer and outputs to the selected pin based on the selected threshold values.
Fc9-type-16-icon.png Connect To
Fc9-type-5-icon.png Output Pin
Fc9-type-21-icon.png Threshold Value
Sets the level at which the pin goes into the active state. >= the threshold the pin will be in the active state. < the threshold the pin will be in the none active state.
Fc9-type-16-icon.png Pin State
Selects the output level to use when the pin is in the active state. Active High - Pin will pull to VCC (high) when active and pull to VSS (low) when none active. Active Low - Pin will pull to VSS (low) when active and pull to VCC (high) when none active.
