Component: Simulated Control Load (DSP)
Revision as of 17:19, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Simulated Control Load component
Allows a simulated load to be connected to the DSP network allowing you to model external factors such as Motor Speed, Motor Position, Temperature, Humidity, Pressure, Flow etc. Useful when used with a feedback based control system.
DSP
Fc9-comp-macro.png SimulateLoadArray
Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end
Simulates a load change with a new control value being applied and a new feedback signal gathered from the output.
Fc9-type-16-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-conn-icon.png Load
Fc9-type-16-icon.png Model Type
Fc9-type-16-icon.png Model Order
The order of a differential equation is the highest degree of derivative present in that equation. A system whose input-output equation is a second order differential equation is called Second Order System.
Fc9-type-8-icon.png 1st Order
Determines to the response of the syecific order within the system. Output = (OldOutput * (1 - Order)) + (NewInput * Order)
Fc9-type-8-icon.png 2nd Order
Fc9-type-8-icon.png Initial Output
