Component: Electrical Machines (AllCode)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category AllCode
Electrical Machines component
A set of functions to communicate with the Matrix EM hardware. Allows the functions to be easily standardised across all SCADA programs.
FREE
Fc9-comp-macro.png GetLogDataReady
Checks to see if the logging is complete and ready to read.
Fc9-comp-macro.png GetRPM
Reads the speed in RPM
Fc9-comp-macro.png GetWeight
Reads the voltage of a single channel
Fc9-u8-icon.png - BYTE Scale
Range: 0-1 - 0=Weight, 1=Torque
Fc9-comp-macro.png SetControlKP
Fc9-comp-macro.png SetControlSetpoint
Fc9-comp-macro.png GetAPIVersion
Reads the API firmware version
Gets a 64-byte packet of log data. 250 packets make up a single log. Returns 0 if comms failed and 1 if comms OK
Fc9-u8-icon.png - BYTE Buffer
Buffer to store the incoming log data
Fc9-comp-macro.png GetDataArray
Collects a data array from the EM box full of control data. Each set of data includes: Setpoint, Feedback, Poutput, Ioutput, Doutput Returns the number of complete data samples collected.
Fc9-f32-icon.png - FLOAT data
Fc9-comp-macro.png GetSafetySwitch
Reads the safety switch
Fc9-comp-macro.png SetControlKI
Fc9-comp-macro.png ZeroLoadCell
Fc9-comp-macro.png SetControlMaxDrivePercentage
Range 0.0-1.0
Fc9-comp-macro.png SetMotorType
Fc9-u8-icon.png - BYTE MotorType
0=DC, 1=1 Phase, 2=3 Phase
Fc9-comp-macro.png SetLoadCellCalibration
Fc9-comp-macro.png GetVoltage
Range: 0-5 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=VEXT
Fc9-comp-macro.png GetControlFeedback
Fc9-comp-macro.png SetControlKD
Fc9-comp-macro.png SetCapacitorBank
Fc9-u8-icon.png - BYTE Cap
Fc9-comp-macro.png GetCommsOK
Checks if comms are ok and stable
Fc9-comp-macro.png GetLogStartAngle
Collects the U Phase angle at the start of logging. Used to calculate and re-create the 3Phase voltage data.
Fc9-comp-macro.png SetVoltage
Sets the DC Voltage from 0 to 24V
Fc9-f32-icon.png - FLOAT Voltage
Fc9-u8-icon.png - BYTE Index
Fc9-comp-macro.png Get3PhaseMode
Checks to see if the brushless mode is enabled
Fc9-comp-macro.png GetAbsPosition
Reads the absolute position of the encoder
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetFan
|Sets the speed of the FAN from 0 (MIN) to 3000 (MAX)
Fc9-u16-icon.png - UINT Speed
Fc9-comp-macro.png SetMotorDirection
Fc9-bool-icon.png - BOOL MotorDirection
0=FW, 1=BW
Fc9-comp-macro.png GetMotorDirection
Reads the motor direction
Fc9-comp-macro.png SetThreePhaseDriveMode
Fc9-bool-icon.png - BOOL Mode
0=Simple, 1=Accurate
Fc9-comp-macro.png GetCurrent
Reads the current of a single channel
Range: 0-6 - 0=DC1, 1=DC2, 2=U, 3=V, 4=W, 5=Dyno, 6=I, 7=TotalDriver
Fc9-comp-macro.png SetFrequency
Fc9-u16-icon.png - UINT Frequency
Frequency of sine wave in Hz
Fc9-comp-macro.png SetDynoLoad
Fc9-f32-icon.png - FLOAT Load
Fc9-comp-macro.png GetErrorStatus
Gets the current error status. Error status will automatically resolve itself once the causing condition has been removed. 0 = No Error 1 = Error - likely over current or brownout
Fc9-comp-macro.png GetControlOutputs
Fc9-f32-icon.png - FLOAT Data
Fc9-comp-macro.png SetActive
Fc9-bool-icon.png - BOOL Active
0=Off, 1=On
Fc9-comp-macro.png SetDriveMode
Fc9-u8-icon.png - BYTE Mode
0=PWM, 1=On/Off/Float
Fc9-comp-macro.png SetTCPProps
Sets the TCP IP address and Port
Fc9-u8-icon.png - BYTE IP0
Fc9-u8-icon.png - BYTE IP1
Fc9-u8-icon.png - BYTE IP2
Fc9-u8-icon.png - BYTE IP3
Fc9-u16-icon.png - UINT Port
Fc9-comp-macro.png SetAbsPosition
Resets the absolute motor position to 0
Fc9-comp-macro.png Initialise
Returns 1 if the connection is ok and communications have been established
0=DC, 1=1Phase, 2=3Phase, 3=AngleControl
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png Comms Mode
Fc9-type-7-icon.png Stop On Error
Automatically allows the runtime to stop if there is a communications error.
Fc9-conn-icon.png USB Communications
Fc9-type-7-icon.png Autodetect Port
Fc9-conn-icon.png Runtime Statistics
Allow console data to be generated showing the high level EM communications and returns
