Component: Touch Screen (FT6X06) (Force)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Force
Touch Screen (FT6X06) component
Low level routines for controlling or interacting with the FT6X06 touch screen controller IC found on a lot of common low cost resistive touch screen products.
SENSORS
Fc9-comp-macro.png ReadXBytes
Reads the specified number of bytes starting at the specified address
Fc9-u8-icon.png - BYTE Data
Fc9-u8-icon.png - BYTE NumBytes
Fc9-comp-macro.png WriteXBytes
Writes the specified number of bytes starting at the specified address
Fc9-comp-macro.png SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
Fc9-comp-macro.png ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
Fc9-u8-icon.png - BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
Fc9-u8-icon.png - BYTE Index
Touch Index Range: 0 - 1
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-conn-icon.png Bus Settings
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Configuration
Fc9-type-16-icon.png Analogue Mode
Fc9-type-21-icon.png X Pixel
Fc9-type-21-icon.png Y Pixel
Fc9-type-7-icon.png Flip X
Fc9-type-7-icon.png Flip Y
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-16-icon.png API
Specifies the API component on the panel to interact with to provide comms simulation.
