Component: Formula AllCode API (AllCode)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category AllCode
Formula AllCode API component
A simulation only component to allow the Formula AllCode robot to be controlled via it's API interface and Bluetooth data connection without having to compile or re-program the robot.
FREE
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
LED Control
Controls the LEDs on the Formula AllCode by collecting the analogue value of a potentiometer on the simulation panel and sending the value to the robot.
FC6 Icon.png LED Control Example
Motor Control Using Keypad
Uses the keypad on the simulation panel to control the speed and direction of the motors. Key 2 drives the robot forwards, 8 drives backwards, 4 and 6 turn the robot on the spot.
FC6 Icon.png Motor Control Example
Motor Control Using Joystick
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
FC6 Icon.png Formula AllCode Bluetooth
Proximity Alarm
Reads the front IR sensor on the Formula AllCode from the Flowcode simulation. If a near object is sensed then the Flowcode simulation will speak the word "Hello" using the Speech component.
FC6 Icon.png Proximity Alarm Example
Driving Simulation using the API component
An example showing how to use the API component to drive the Formula AllCode robot component on the simulation panel.
FC6 Icon.png FA API Sim Demo
JCB Bot Blog
Blog with example code showing how to drive the Formula AllCode robot using Key Mappings and how to add extra features such as a 3D printed cover and servo motors to operate a digger arm and bucket.
JCB Bot
Fc9-comp-macro.png PlayNote
Plays a note using the speaker on the FA
Fc9-u16-icon.png - UINT Note
Range 1 to 65535 in Hz
Fc9-u16-icon.png - UINT Delay
Number of milliseconds to play the note for
Fc9-comp-macro.png LEDOn
Sets a single LED 0-7
Fc9-u8-icon.png - BYTE index
Range: 0-7
Fc9-comp-macro.png LCDPrintString
Prints a string to the LCD
Fc9-u8-icon.png - BYTE X
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y
LCD Y Coordinate 0-31
Fc9-comp-macro.png ReadLight
Reads the light sensor 0-4095 - 4095 = Max Brightness
Fc9-comp-macro.png Right
Rotates the robot right - waits for the angle to be traversed before returning
Fc9-u16-icon.png - UINT Angle
Angle to turn in degrees
Fc9-comp-macro.png SetLogoSpeed
Sets the speed of logo movements
Fc9-u8-icon.png - BYTE Speed
Logo Speed 1-100 - Default 40
Fc9-comp-macro.png ReadAllSensors
Samples all of the robot's sensors at once, storing the values locally
Fc9-comp-macro.png SampleMag
Samples the magnetometer 0 = no new data, 1 = new data available
Fc9-comp-macro.png CardCreate
Attempts to create a file on the SD card 255=Error, 1=File Already Exists, 0=Create OK
Fc9-comp-macro.png LCDPrintNumber
Prints a 16-bit signed number to the LCD
X Pixel 0-127
LCD Y coordinate 0-31
Fc9-s16-icon.png - INT Number
Range -32768 to 32767
Fc9-comp-macro.png LEDOff
Clears a single LED 0-7
Range: 0-7
Fc9-comp-macro.png LEDWrite
Sets the value of the LEDs as an 8-bit output
Fc9-u8-icon.png - BYTE Value
LED value 0=All Off, 255 = All On
Fc9-comp-macro.png ReadAxis
Reads a single X/Y/Z axis from the accelerometer sensor.
0=X, 1=Y, 2=Z
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ServoSetAutoMoveSpeed
Changes the speed of the auto movements Default - 1
Range 1-50
Fc9-comp-macro.png CardPlayback
Plays back a .Wav file audio stream from the card
Fc9-comp-macro.png ReadMic
Reads the microphone sensor 0 - 4095
Fc9-comp-macro.png ReadSwitch
Read the switch value
0 (left) or 1 (right)
Fc9-comp-macro.png SampleAccel
Samples the accelerometer 0 = no new data, 1 = new data available
Fc9-comp-macro.png Left
Rotates the robot left - waits for the angle to be traversed before returning
Fc9-comp-macro.png ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
Fc9-comp-macro.png LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
X Pixel 0-127
Y Pixel 0-31
Fc9-u8-icon.png - BYTE State
0=White (Off), 1=Black (On)
Fc9-comp-macro.png ServoSetPosition
Allows one of the servo positions to be assigned
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Range 0-127
Range 0-31
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Range 0-255
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
0=Left, 1=Right
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
0=Left, 1=Right
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
Fc9-s16-icon.png - INT Left
Range -100 to 100
Fc9-s16-icon.png - INT Right
Range -100 to 100
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Distance in mm
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
0=Off 1=On
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png LCDClear
Clears the LCD
Fc9-type-16-icon.png COM Port
Selects which port to communicate with, only lists ports which are currently available.
Fc9-type-7-icon.png Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Fc9-type-14-icon.png Baud
Baud rate passed to the COM port to control the rate of data.
Fc9-type-10-icon.png Label
