Component: GPS (EB056, Generic NMEA) (Wireless)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Wireless
GPS (EB056, Generic NMEA) component
Component designed to process incoming NMEA style GPS data and convert into meaningful values such as longitude, lattitude, ground speed, UTC date and time. Also available in the form of the EB056 GPS E-block.
COMMSB
GPS Example File FC6 Icon.png GPS Example Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GPS tracking application using an Arduino and an SD card reader. FC6 Icon.png GPS Tracker
Fc9-comp-macro.png ReadGroundSpeed
Returns the current ground speed. Only returns correct data if Log Ground Speed property is set to yes.
Fc9-comp-macro.png ReadNumberOfSatellites
Returns the current detected number of satellites. Only returns correct data if Log Satellite Count property is set to yes.
Fc9-comp-macro.png ReadDilutionOfPrecision
Returns the current dilution of precision. Only returns correct data if Log Dilution Of Precision property is set to yes.
Fc9-comp-macro.png CheckBufferOverflow
Returns the state of the buffer - 0 = OK, 1 = BufferTooShort, 2 = ItemNotFound. Only returns correct data if Log Buffer Overflow Property is set to Yes.
Fc9-comp-macro.png ReadLongitude
Returns the current longitude. Only returns correct data if Log Longitude property is set to yes.
Fc9-comp-macro.png ReadUTCTime
Returns a segment of the current UTC Time. Only returns correct data if Log UTC Time property is set to yes.
Fc9-u8-icon.png - BYTE Unit
Specifies which segment to read - 'h', 'm', 's'
Fc9-comp-macro.png IsDataValid
Returns the state of the incoming data - 0 = NotValid, 1 = Valid 255 = No GPS Data Received.
Fc9-comp-macro.png ReadHorizontalDilutionOfPrecision
Returns the current horizontal dilution of precision. Only returns correct data if Log HDOP property is set to yes.
Fc9-comp-macro.png ReadAltitude
Returns the current altitude. Only returns correct data if Log Altitude property is set to yes.
Fc9-comp-macro.png ReadCourseOverGround
Returns the current course over ground. Only returns correct data if Log Course Over Ground property is set to yes.
Fc9-comp-macro.png ReadUTCDate
Returns a segment of the current UTC Date. Only returns correct data if Log UTC Date property is set to yes.
Specifies which segment to read - 'd', 'm', 'y'
Fc9-comp-macro.png ReadVerticalDilutionOfPrecision
Returns the current vertical dilution of precision. Only returns correct data if Log VDOP property is set to yes.
Fc9-comp-macro.png ReadLatitude
Returns the current latitude. Only returns correct data if Log Latitude property is set to yes.
Fc9-comp-macro.png Initialise
Initialises the UART used to communicate with the GPS module.
The maximum number of bytes of a NMEA message we can store before processing the message.
Fc9-type-7-icon.png Log Altitude
Adds a variable to store the incoming altitude value Referenced by macro: ReadAltitude
Fc9-type-7-icon.png Log Buffer Overflow
Adds a variable to store if the incoming message buffer overflows Referenced by macro: CheckBufferOverflow
Fc9-type-7-icon.png Log Course Over Ground
Adds a variable to store the incoming course over ground value Referenced by macro: ReadCourseOverGround
Fc9-type-7-icon.png Log Dilution Of Precision
Adds a variable to store the incoming DOP value Referenced by macro: ReadDilutionOfPrecision
Fc9-type-7-icon.png Log Ground Speed
Adds a variable to store the incoming ground speed value Referenced by macro: ReadGroundSpeed
Fc9-type-7-icon.png Log Horizontal DOP
Adds a variable to store the incoming HDOP value Referenced by macro: ReadHorizontalDilutionOfPrecision
Fc9-type-7-icon.png Log Latitude
Adds a variable to store the incoming latitude value Referenced by macro: ReadLatitude
Fc9-type-7-icon.png Log Longitude
Adds a variable to store the incoming longitude value Referenced by macro: Read Longitude
Fc9-type-7-icon.png Log Satellite Count
Adds a variable to store the number of satellites in range Referenced by macro: ReadNumberOfSatellites
Fc9-type-7-icon.png Log UTC Time
Adds a variable to store the incoming UTC Time value Referenced by macro: ReadUTCTime
Fc9-type-7-icon.png Log UTC Date
Adds a variable to store the incoming UTC Date value Referenced by macro: ReadUTCDate
Fc9-type-7-icon.png Log Verticle DOP
Adds a variable to store the incoming VDOP value Referenced by macro: ReadVerticalDilutionOfPrecision
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Fc9-type-7-icon.png Show Globe
Allows a graphical globe to be shown on the panel along with a coordinate marker.
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
