Component: Water Sensor (Grove 101020018) (101020018) (Environmental)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Category Environmental
Water Sensor (Grove 101020018) component
The water sensor uses a 1M ohm pull-up resistor. The resistor will pull the sensor trace value high until a drop of water shorts the sensor trace to the ground trace. You can use it with an analog input pin to detect the amount of water in contact between the grounded and sensor traces.
SENSORS
Fc9-comp-macro.png GetIntValue
Returns the analog reading as an integer value.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetFloatValue
Reads the analog value as a floating point value between 0 and 100
Fc9-conn-icon.png Simulation
Fc9-type-1-icon.png Tang Color
Colour of the moving part of the slider.
Fc9-type-1-icon.png Marker Color
Colour of the marker line across the slider tang.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-14-icon.png Aquisition cycles
