Component: LED Bar v2.0 (Grove 104020006) (104020006) (LEDs)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Category LEDs
LED Bar v2.0 (Grove 104020006) component
LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip. It can be used as a indicator for remaining battery life, voltage, water level, music volume or other values that require a gradient display. There are 10 LED bars in the LED bar graph: one red, one yellow, one light green, and the rest green. It lights up the LEDs sequentially from red to green, so the entire bar graph is lit up in the end.
SENSORS
Fc9-comp-macro.png SetBinary
Allows a binary value to be shown on the LEDs. Red = Bit0 Yellow = Bit1 Light Green = Bit2 Green = Bit3 - Bit9
Fc9-u16-icon.png - UINT Data
Fc9-comp-macro.png LatchDataSim
Latches the data and shifts the new input to the output.
Fc9-comp-macro.png SetLevelReverse
Set level 0-10 in reverse, green to red, where 10 is red Level 0 means all leds off while level 5 means leds 1-5 on and 6-10 will be off
Fc9-u8-icon.png - BYTE Level
Range: 0-10
Set level 0-10, red to green, where 1 is red Level 0 means all leds off while level 5 means leds 1-5 on and 6-10 will be off
Range: 0-10
Fc9-comp-macro.png SetSingleLED
Allows a single LED to be controlled and switched on or off. LED 0 = Red LED 1 = Yellow LED 2 = Light Green LED 3-9 = Green
Fc9-u8-icon.png - BYTE LED
Range: 0-9
Fc9-u8-icon.png - BYTE State
0=Off / 1=On
Fc9-type-5-icon.png Data
Data pin
Fc9-type-5-icon.png Clock
Clock pin
