Component: Light Sensor (Grove 101020132) (101020132) (Light)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Category Light
Light Sensor (Grove 101020132) component
The Light sensor module is a simple analogue photo transistor. Used to detect the intensity of the indoor light.
SENSORS
Fc9-comp-macro.png GetString
Reads the ADC as a direct voltage and returns as as tring
Fc9-comp-macro.png GetAverageByte
Function call to read the ADC as a byte average sample over time
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
Number of micro seconds in between taking each sample
Fc9-comp-macro.png GetAverageInt
Function call to read the ADC as a full width average sample over time
Fc9-comp-macro.png GetVoltage
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
Fc9-conn-icon.png Simulation
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
Fc9-type-14-icon.png Aquisition cycles
