Component: Relay (Grove 103020005) (103020005) (General Output)
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category General Output
Relay (Grove 103020005) component
The Relay is a digital normally open switch capable of switching much higher voltages and currents than your normal Microcontroller outputs. When set to HIGH, the LED will light up and the relay will close allowing current to flow. The peak voltage capability is 250V at 10 amps. Simulated component, green indiacator is on when the relay is active.
SENSORS
Fc9-comp-macro.png SwitchOn
Switch on the relay, connecting the common pin to the normally open pin.
Fc9-comp-macro.png SwitchOff
Switch off the relay, disconnecting the common pin from the normally open pin.
Fc9-type-5-icon.png Control Pin
