Component: Rotary Angle Sensor (Grove 101020017) (101020017) ()
Revision as of 17:20, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.4
Category
Rotary Angle Sensor (Grove 101020017) component
The Rotary Angle sensor is based on a simple analogue potentiometer.
BASICIO
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
Colour of the pointer.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
