Component: Data Transfer (API UART) ()
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category
Data Transfer (API UART) component
Comms data injector to allow a Serial UART peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical UART.
FREE
Fc9-comp-macro.png InitialiseInjector
Fc9-string-icon.png - STRING InjectorName
Fc9-comp-macro.png TxByte
Fc9-u8-icon.png - BYTE DataByte
Fc9-comp-macro.png RxByte
Fc9-comp-macro.png ChangeState
Sets the state of the bus. SPI - Controls the chip select pin I2C - Controls the start/restart/stop status
Fc9-u8-icon.png - BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
Fc9-type-17-icon.png SCADA Slave
Fc9-type-16-icon.png BAUD Rate
Sets the data bit rate of the Serial UART. See the SCADA Slave UART Baud macro for valid values,
Fc9-type-7-icon.png RS485 Direction Control
Allows an I/O pin to be automatically assigned when transmitting and receiving.
Fc9-conn-icon.png RS485 Properties
Fc9-type-21-icon.png RS485 Pin Number
Digital I/O pin number to use for the RS485 data direction pin
Fc9-type-16-icon.png TX Pin State
Decides the state of the RS485 data direction pin when transmitting data.
Fc9-type-16-icon.png RX Pin State
Decides the state of the RS485 data direction pin when receiving data.
